 Adrian Flux
» Tyres by on Thu 14 Feb 19 19:16
Under bonnet light
Nigelcurry
Wed 16 May 18 19:07
Under bonnet light
Hi all
Not a very important thing on the whole I know,but when I took possession of my 79 coupe in a box along with other odds and sods was the light for under the bonnet,itís quite a simple set up except there is a black wire soldered on to the outside of the lamp?there is only one cable coming in to the lamp (the live feed in)so I am assuming the black lead is bolted some where to make earth.Blessed if I can find any where to make up an earth as the lead in question is only about 4/5 inches long with a lug on the end,
Any thoughts out there
Nige
curious bystander
Thu 17 May 18 08:07
Re: Under bonnet light
It goes under the nearest bolt on the bonnet stay bar to earth through to the chassis.
The switch to operate the light is a mercury type which I assume is part of the bulb holder?
79 L82 Auto
Having a lot of bhp is all very well, but on these forums it's torque that counts
Club Secretary
Nigelcurry
Thu 17 May 18 10:00
I have checked that out and thatís spot on,however the switch is the same as the interior door open/ close operation type sited in a suitable site to be switched on when lifting bonnet but both wires connected to it are dead,and disappear in to the loom.The wire feeding the lamp comes from a perm /live red wire exiting the loom on the inner wing??any one got any ideas ! And thanks for the info/help so far lads
Thu 17 May 18 10:01
I was always concerned that the under-hood lamp did not actually go off when the hood was closed. So, I installed a switch below it, in the power line. At the time it was OK, now I know that neater, smaller rocker-type switches are available which would make the job a bit more professional! But it means I can be sure its off and, I only have it on when I need it.
Both wiring and my switch just may be visible in this photo:
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
curious bystander
Thu 17 May 18 10:18
Nigel - the on/off switch you refer to - is it the one half way across the bulkhead near the wiper motor?
I believe that's an alarm switch - isn't it Stephen?
79 L82 Auto
Club Secretary
Nigelcurry
Thu 17 May 18 12:46
Your all spot on lads I did some research of my own and your info is correct,thanks a million you guys
Nige
Fri 18 May 18 11:03
curious bystander wrote (View Post):Nigel - the on/off switch you refer to - is it the one half way across the bulkhead near the wiper motor?
Ooops - I missed this! But Nigel has it all sussed now! Thumbs up
The alarm Surprised Another electrical minefield - the alarm horn was disconnected when we got ours, for good reason it seems, as I'm not sure it isn't always armed! I won't be investigating I'm afraid, even after 28 years of ownership Very Happy
Stephen J Irons
NCM Family Member
Apple IS Genisys!
curious bystander
Fri 18 May 18 12:24
Mines disconnected now. When I first got the car something happened and it went off unexpectedly.
So loud I couldn't believe it - like a ships foghorn Doh
79 L82 Auto
Club Secretary
5 USA
Fri 18 May 18 19:26
curious bystander wrote (View Post):...something happened and it went off unexpectedly.
Be careful. GCHQ is listening.... Wink
Quick reply to topic
Username:
Reply to topic:
You can reply to threads in this forum
You can edit your posts in this forum
You can delete your posts in this forum
