 Lancaster Insurance
Jacking whole car onto axle stands
stiej
Mon 21 May 18 12:51
What is the best procedure to get the car onto four axle stands? Where must each axle stand go front and rear? Iíve got a convertible so does presence of x brace change anything? Also can I open the bonnet after Iíve got it on axle stands?
roppa440
Tue 22 May 18 08:37
Re: Jacking whole car onto axle stands
I'm not familiar with the C4 chassis but in general I use chassis or subframe points to support with axle stands. Jack up one end or side at a time. In stages depending how high you want it.
Because my C5 is so low I have to jack up one side at a time and put blocks under the wheels. Then I can get the jack under the front to lift it in the centre of the subframe high enough to get it in stands. Then I do the same at the rear.
Once supported evenly on the frame you can indeed open doors and bonnet.
BlackZeD
Tue 22 May 18 11:40
Google C4 jacking points, plenty info and pics there.
Don't take life too seriously, after all, your not coming out of it alive.
stiej
Fri 25 May 18 21:27
Thanks. Found some good ones.
Ant1981
Awww... join the CCCUK!
Mon 25 Jun 18 19:54
What I do on the C4, to make things safer, I use concrete blocks with timber on top and use that to support the car from the front crossmember in between the wishbones and axle stands at the rear.
1985 - C4 Red Auto - Sold
2002 - VW Golf GTi Turbo
2009 - Kawasaki Ninja ZX-6R
Nothing to prove? Proved to be rip off artists with a bad attidude.
