 ShipMyCar.co.uk
Engine cutting out after firing up
roppa440
Mon 15 Oct 18 08:33
Just thought I would mention the problem I had last week with my car not running in case this ever happens to someone else.
Symptom was engine cranked and fired up but then died.
It didn't help in my case that I had just had the throttle body and MAF sensor off the car which lead me down several diagnostic paths ending in Red Herrings. In the end that was just coincidence.
Fault codes were no use. I was getting some strange ones including faults about the AC system. Non of those were relevant in finding the fault it turned out.
The only fault warning that ended up relevant was a "Low Oil Level" on the dash despite the oil level being fine.
When I checked for fuel pressure at the Schrader valve on the fuel rail I couldn't get any. Then I noticed I couldn't hear the fuel pump running.
This lead to another string of red herrings trying to find out why the fuel pump wasn't working.
In the end it was of course something bloody simple.
There is an earth strap that runs from the inner fender to the side of the engine block. It fixes to the block with a bolt. Also on the bolt is the ground from the engine oil level sensor.
A bad connection at either end will stop the fuel pump from powering up. And of course can also throw up a low oil warning.
In my case the bolt into the block was actually loose and half way out. So the wires were just touching.
Only took me a week to find it and that was with help from the guys on the US forum. But all the red herrings made isolating the fault tricky in my case.
Norm
Mon 15 Oct 18 14:52
Re: Engine cutting out after firing up
Same symptoms on my buddies '90 ZR1, sometimes it's the simple things that get you.
Glad you got it squared away.
From Delmarva, USA
NCM Member
2016 Z06 Coupe A8 Black, Red & Ebony Int.
1975 L82 A3 T-Top, Bright Blue, Custom Blue & Black Interior (NCRS for me, Not Correctly Restored Stingray)
Previously Owned Vettes: '65, '97, '01, '10, '14
Firepit
Mon 15 Oct 18 21:56
Do you have any pictures of the offending connections?
Cheers
C5 in custom made Firepit Orange color with Billy Boat Bullet exhaust, MGW short shift, Wilwood Superlite front brakes, Venair Orange Silicon hoses and Evans waterless coolant. Custom mural under hood with wheels and other accessories in Thunder Grey. Illuminated Sills and Firepit Orange interior.
roppa440
Tue 16 Oct 18 08:14
Firepit wrote (View Post):Do you have any pictures of the offending connections?
Cheers
This is the one on the drivers side of the block towards the rear. (Not a photo of my car as I have headers that would make it hard to see)
The other end of the earth strap goes to a vertical stud on the inner wing just under the brake booster.
The black wire is the ground connection for the oil level indicator.
Firepit
Tue 16 Oct 18 08:19
Cheers for that. Very handy if similar symptoms are encountered. Smile
