Can you identify this engine?
Author |
Message |
Club Member |
Wed 02 Jan 19 10:42 Can you identify this engine? So I have a recently imported C3 with a non-factory engine. Initially described as a “corvette engine, from a later model” i have been struggling to identify what the donor car was (if it was a ‘vette at all).
Club Member |
Wed 02 Jan 19 10:56 Re: Can you identify this engine? The casting number is your main point of reference. I think it should be stamped on a small flat section at the rear of the block, driver's side, below the cyl. head.
Club Member |
Wed 02 Jan 19 15:07 Re: Can you identify this engine? As Jack sys, the Casting Number is at the rear of the block, but may be hard to see without a mirror.
Club Member |
Wed 02 Jan 19 19:37 Re: Can you identify this engine? The block casting number should be easily visisible. It's below the middle tee piece vac affair on the tast pic where block meets belhousing.
Club Member |
Wed 02 Jan 19 19:44 Re: Can you identify this engine? Correct, no power brakes or steering. Unlike the engine, alternator and fan spacer (extruded aluminium in the 1970’s?) I think these are original.
Committee Member |
Wed 02 Jan 19 20:04 Re: Can you identify this engine? What he means is that heater hose instead of being 'fed' from water pump spigot outlet to heater inlet port - simply goes to the heater return spigot on the engine - short circuiting the heater. Engine seems to be a centre bolted lump perhaps out of a 80's C4 or Camaro???????
Club Member |
Committee Member |
Wed 02 Jan 19 20:16 Re: Can you identify this engine? L88 wrote (View Post):Or truck!
Club Member |
Club Member |
